Rank:: Member
This unit was running and quit when almost done with a wash. The front panel cycle lites will not lite up, and it will not run, but when you press the on/off button with the door latched you can almost hear the motor try and run (I can here a very quick noise. Don't know if it's the motor or a solenoid. Today I pressed the on/off switch and it started to drain for a few seconds and quit, but the cycle light did not lite up at any time. Any ideas? Wil
