Hello, During a move recently, the timer control dial broke off my Frigidaire dryer (model FSEC346RHSO). Thinking it was just the dial, I ordered a new one, only to figure out it's actually the little piece of metal that connects the dial with the timer that is broken.
My question is this : Is it possible to repair/replace this piece of metal without having to replace the whole timer unit which costs a hefty amount?
Also, I was wondering if I could find instrucions on how to open the dryer front panel to see the actual unit.
Thanks in advance.
You will need to replace the timer.
Thanks, that's a downer though. Would it be possible to have it welded back together?
