ddcmbv
#1 Posted : Sunday, November 20, 2011 5:09:18 PM(UTC)
ddcmbv
This machine would not clean dishes and never filled with water, despite the fact that water was entering the machine. I noticed the solenoid plunger was severely corroded and stuck so that the pump door was always in the drain mode. The motor was working and the machine was draining perfectly well. I jiggled the solenoid plunger and got the machine into the wash mode but the solenoid would still get stuck in the drain mode. It appeared that the cause for the corroision of the solenoid plunger was leakage around the solenoid linkage where it entered the pump body. So I decide to replace the entire pump and motor assembly.
After the replacement the machine worked well for a couple of cycles, but now it will not drain. I again looked at the solenoid and saw that it was cycling but the pump door was not fiully engaging in the drain mode. When I helped the solenoid engage the pump door in the drain mode by pushing down on the linkage when the solenoid tried to go into the drain mode, the pump door switched to the drain mode and the machine drained very quickly and completely, then cycled off. At the start of the enxt cycle the machine filled and washed but again the solenoid did not appear to have enough "oomph" to get the pump door to go into the drain mode.
Any ideas?
#2 Posted : Monday, November 21, 2011 6:34:11 AM(UTC)
Here are your parts.
Replacement parts for General Electric GSD5114D00AA Dishwasher | AppliancePartsPros.com
Since the pump/motor are new and I assume it came with a new solenoid, it sounds like the replacement is defective. Try loosening the solenoid mount and repositioning it so the plunger pulls in and releases fairly easy.
The way the wash/drain works is that the control board sends power to the solenoid for a couple seconds. This should pull the plunger all the way down and set the flapper valve to the drain position. The water pressure then keeps the flapper in the drain position till the unit is empty. The solenoid springs then pull it back to the ash position.
Another common problem that you may want to check is the piston and nut assembly (Item 564 in Section 2). It is under/behind the screened cover at the back of the tub and unscrews. If this valve leaks then water is pumped back into the tub instead of out the drain during a drain cycle so water is left in the unit after drain.
ddcmbv
#3 Posted : Monday, November 21, 2011 6:45:44 PM(UTC)
ddcmbv
The assembly did come with a new solenoid. After sleeping on this problem, I looked at the old cruddy solenoid and at the new solenoid. For want of a better term, there is a "wing" that is engaged when the solenoid is energized and the plunger is down. This "wing" was bent on the new solenoid, but not on the old solenoid. I was able to switch out this "wing" and the attached spring from the old to the new solenoid and everything works like a charm.
On close inspection, I could see a crease in the "wing" from the new solenoid. It looked like the solenoid had been dropped and the wing bent at some point before it was installed on the assembly. It would be very difficult to bend this "wing" after the solenoid is installed because it is protected by the motor on one side and the pump and solenoid body on the other sides.
In my field there is a saying to the effect that you should think of horses, not zebras, when you hear hoofbeats. In this case the hoofbeats were those of a zebra.
Thanks very much for the prompt reply.
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Bosch SHU33 dishwasher won't drain when hot just after a wash (Dishwasher Repair)
by Guest 7/12/2021 7:43:33 AM(UTC)
Bosch dishwasher won't drain, begins cycle, then stops - FIXED (Dishwasher Repair)
by mabradbury 1/17/2019 7:08:25 PM(UTC)
Bosch dishwasher won't drain completely (Dishwasher Repair)
by nathaniel.hoffman@gmail.com 12/25/2018 6:30:47 AM(UTC)
GE dishwasher won't drain after last rinse cycle (Dishwasher Repair)
by autotech1 1/22/2018 9:47:40 AM(UTC)
Dishwasher won't drain (Dishwasher Repair)
by Drummabouy 6/22/2017 6:29:14 AM(UTC)
Dishwasher Won't Drain or Run Cleaning Cycle (Dishwasher Repair)
by Katie L 8/4/2016 2:07:24 PM(UTC)
Bosch Dishwasher won't drain and goes directly to "Clean" Light (Dishwasher Repair)
by ed3120 6/4/2016 4:40:01 AM(UTC)
by brokenge 2/18/2016 2:32:59 PM(UTC)
Frigidaire dishwasher won't drain (Dishwasher Repair)
by kohanz 12/4/2015 9:35:55 PM(UTC)
Dishwasher won't drain! (Dishwasher Repair)
by Crafter_Man 10/12/2015 4:30:35 AM(UTC)
GE Dishwasher won't drain all way (Dishwasher Repair)
by AnthonyJS02 1/10/2015 9:12:07 AM(UTC)
by av0612 8/6/2014 4:42:36 PM(UTC)
Frigidaire Gallery Series Dishwasher won't drain fully after disposal replacement (Dishwasher Repair)
by wicked94pgt 7/17/2014 7:31:44 PM(UTC)
GE Dishwasher won't drain (Dishwasher Repair)
by crabbygardener 6/10/2014 6:30:07 PM(UTC)
