mansoor ali
#1 Posted : Sunday, December 16, 2007 6:40:07 PM(UTC)
mansoor ali
When I press the Hold Start button on my washer the machine no longer starts. All the lights on the control panel are working and switching modes are working but the machine wouldn't start. Can you help? If its a fault in one of the circuit boards then I can change that, but which one.
kawfeeman
#2 Posted : Sunday, December 16, 2007 6:45:48 PM(UTC)
kawfeeman
just out of curiousity, if you remove the three screws that hold the kick / toe panel on, is there a little packet with troubleshooting info... you'll need to access the service mode to determine fault code..
Whirpool duet washer leaks water+detergent after load finished (Washer Repair)
by waylo 1/25/2015 9:47:32 PM(UTC)
Whirpool Duet Washer new circut board wont work F11 code still up (Washer Repair)
by Rickvial88 7/10/2013 7:33:37 AM(UTC)
whirpool duet washer door is not opening staying locked (Washer Repair)
by sonya46 10/23/2011 6:12:22 AM(UTC)
Whirpool Duet Washer wont start (Washer Repair)
by smooothopr 6/8/2011 5:32:27 AM(UTC)
whirpool duet washer (Washer Repair)
by deadhead 7/12/2008 11:55:59 AM(UTC)
