sparky110
#1 Posted : Wednesday, June 3, 2009 12:38:33 PM(UTC)
sparky110
Is there a trick to disengaging the rentention clips that hold the front lower panel in place on a dryer? I'm using a putty knife but nothing happens.
thankyou!
applianceman
#2 Posted : Wednesday, June 3, 2009 5:21:34 PM(UTC)
applianceman
On most Whirlpool dryers you have to pull the filter out top of the dryer and remove the screws under it for the top to lift up. [FONT='Times New Roman']Once the top is up the front is held on by screws. Hope this helps! Clothes Dryer Repair Guide[/FONT]
sparky110
#3 Posted : Wednesday, June 3, 2009 5:38:35 PM(UTC)
sparky110
It's the screws not clips that hold the panel on - the mfg. info was incorrect. thanks for straighting this out!
