2 Pages12>
asalott2
#1 Posted : Saturday, November 19, 2011 1:42:09 PM(UTC)
asalott2
After my refrigerator went warm, I disconnected the ptc to find that the ceramic disc inside was literally cracked in half. I cannot find the replacement part anywhere so I was going to install a 3 in 1 to repair the fridge. are there any better alternatives out there for me? anywhere to find a replacement part for the refrigerator?
#2 Posted : Sunday, November 20, 2011 1:31:05 AM(UTC)
Never use a 3 n 1 hard start kit, they will blow out a modern R134A compressor. They are fine for the older R12 compressors. Just check the name plate to verify R143A refrigerant and also post the correct model#
asalott2
#3 Posted : Monday, November 21, 2011 4:02:40 AM(UTC)
asalott2
Thevunit is definitely r134a and the model is frc445gb. It is a frigidaire 4.4 mini fridge with freezer compartment.
asalott2
#4 Posted : Monday, November 21, 2011 4:05:59 AM(UTC)
asalott2
#5 Posted : Monday, November 21, 2011 7:16:25 AM(UTC)
Your unit is probably not in the data base yet. You can call Lowes, they usually can get parts in a short amount of time, if not let us know and we can help in using a un iversal start device.
asalott2
#6 Posted : Monday, November 21, 2011 11:32:03 AM(UTC)
asalott2
Yeah unfortunately I am an rtm clerk at lowes and I myself am having no luck finding this part. For whatever reason our appliance parts hotline isnt working and my repair companies for appliances havent been helpful as well. Think I need to go with a universal.
The fridge is an old model, probably 5 years old. Anything starting with frc445 should he the same. The last 2 digits are usually for unit finish.
#7 Posted : Monday, November 21, 2011 1:41:56 PM(UTC)
Is your old start device a coil and switch, or a square, black plastic ptcr?
ScottEge
#8 Posted : Monday, November 21, 2011 1:47:33 PM(UTC)
ScottEge
I would recommend ohming out your compressor, because something made that disk pop, wheter it be a storm, surge. a common start device may work. I like the part # 8201799 myself it comes with a new overload as well. As a Tech if this doesn't get the compressor to start you know you have a bad pump. If you have a tech check all he can tell you whether it better to repair or replace the unit.
#9 Posted : Tuesday, November 22, 2011 12:56:21 AM(UTC)
For Scottege:
I dislike you making uninformed comments on my post. You have NO info on this persons refrigerator, at best, you advice will not work, at worst, it will blow out his compressor!
These unprofessional type comments have no place in this forum.
ScottEge
#10 Posted : Thursday, November 24, 2011 3:26:32 PM(UTC)
ScottEge
Mr. Happy I guess they don't your perfectly capible of blowing up refrigerators on your own. Have a Happy Day! I've only been servicing these things 28 years and just like to help and honest person and sheare my experience. You however I have my doubts.
2 Pages12>
