kwheetley
#1 Posted : Saturday, December 15, 2007 3:53:31 PM(UTC)
kwheetley
So randomly in the middle of doing a load of laundry, the dryer started sounded like the were tennis shoes bouncing around in it, and then it started sounding like metal rubbing metal as well. I took a look and the belt is fine, but when I try to spin the tumbler, it is very tough and makes the same sound. When I lift up on the front of the tumbler, it moves and sounds as it should. Did something that supports the tumbler break? Please help, and thank you.
Katie~
misterfixall
#2 Posted : Sunday, December 16, 2007 6:36:51 PM(UTC)
misterfixall
rear drum shell bearing. expensive repair ,hundreds.
misterfixall
#3 Posted : Thursday, December 20, 2007 6:14:46 PM(UTC)
misterfixall
i mistakingly thought you were talking about front load washer ,sorry ,sound s like rear drum bearing is worn out .inexpensive repair .if that all is broken
