macattack
#1 Posted : Saturday, May 30, 2009 6:21:42 AM(UTC)
macattack
maytag washer won't spin or do anything but let water in won't let water go out
applianceman
#2 Posted : Saturday, May 30, 2009 1:38:23 PM(UTC)
applianceman
Will the motor run?
No, if the motor will not run I would check the lid switch.
Yes, if the motor will run check the water pump. Often on these models a sock or rag will clog the pump.
Will the motor run?
Clothes Washer Repair Guide
