maytag washer won't spin or do anything but let water in won't let water go out
Will the motor run? No, if the motor will not run I would check the lid switch. Yes, if the motor will run check the water pump. Often on these models a sock or rag will clog the pump. Will the motor run? Clothes Washer Repair Guide
