jta500
#1 Posted : Wednesday, May 27, 2009 4:11:01 PM(UTC)
jta500
Dryer wont start,then turns on by itself later
sidfink43
#2 Posted : Thursday, May 28, 2009 5:07:07 PM(UTC)
sidfink43
Wow, this is unusual. Does it spontaneously start when the timer is in the off position?
First, let's confirm or eliminate the start switch as the problem.
Unplug the dryer, then take off the console and tape the two wires that connect to the start switch together. Then plug in the dryer. If it starts, then you will need to replace the start switch. (do not operate the dryer in this manner!) If not, post and let's see if we can come up with something else.
Good luck.
LG Dryer wont turn on (Dryer Repair)
by stz2 7/28/2021 2:09:54 AM(UTC)
Kenmore Dryer Wont Turn On (Dryer Repair)
by tmurphy12 11/11/2017 5:37:21 PM(UTC)
Dryer wont turn on. Nothing at all (Dryer Repair)
by jim5775 2/7/2013 1:31:10 PM(UTC)
Dryer wont turn on, bulb stays on when door closed (Dryer Repair)
by mazw 7/24/2012 4:21:01 PM(UTC)
Dryer wont turn on, bulb stays lit when door closed (Dryer Repair)
by mazw 7/24/2012 4:13:34 PM(UTC)
by sweetness 6/21/2012 12:24:11 PM(UTC)
admiral dryer wont turn on (Dryer Repair)
by tammy27 6/12/2012 1:08:36 PM(UTC)
by G.A.Russell 2/12/2012 12:42:26 PM(UTC)
by blackcobra427 11/2/2011 9:31:12 AM(UTC)
Roper Dryer wont turn on (Dryer Repair)
by edwardsnl 1/15/2011 12:37:58 PM(UTC)
by snooki 12/2/2010 5:45:01 PM(UTC)
by ritadi 7/4/2010 9:30:53 AM(UTC)
by carri0321 3/29/2010 1:34:12 PM(UTC)
lady kenmore ultra fabric care electric dryer wont turn on (Dryer Repair)
by John414 3/6/2010 7:19:25 AM(UTC)
Frigidaire dryer wont turn on (Dryer Repair)
by gamermom79 1/13/2010 11:15:41 AM(UTC)
