This is a double stacked unit and the dryer has an ear splitting squeal to it. This must be a bearing or bushing. How can I get an exploded parts diagram? Thanks
In your opinion, will replacing the drum support bearing fix the squeak or is the drive belt involved, perhaps the belt idler? Thanks
I think the drum support bearing will do the trick, it almost always does. Don't think the belt is a problem and you can certainly lubricate the idler wheel while you are in there (be careful not to get any lubricant on anything). Also, take the opportunity to thoroughly clean, particularly the vent system.
Good luck, and keep us informed.
