butchphipps
#1 Posted : Wednesday, May 27, 2009 4:47:16 AM(UTC)
butchphipps
This is a double stacked unit and the dryer has an ear splitting squeal to it. This must be a bearing or bushing. How can I get an exploded parts diagram?
sidfink43
#2 Posted : Wednesday, May 27, 2009 8:39:22 AM(UTC)
sidfink43
See if this doesn't help you.
http://manuals.frigidaire.com/p...f/Webster/5995519542.pdf
You can also see an exploded view of your machine by clicking on the model number and APP will give you much the same as the above site.
Good luck.
butchphipps
#3 Posted : Wednesday, May 27, 2009 8:47:22 AM(UTC)
butchphipps
In your opinion, will replacing the drum support bearing fix the squeak or is the drive belt involved, perhaps the belt idler?
sidfink43
#4 Posted : Wednesday, May 27, 2009 9:24:20 AM(UTC)
sidfink43
I think the drum support bearing will do the trick, it almost always does. Don't think the belt is a problem and you can certainly lubricate the idler wheel while you are in there (be careful not to get any lubricant on anything). Also, take the opportunity to thoroughly clean, particularly the vent system.
Good luck, and keep us informed.
