Does anyone know how to take the ice dispenser front panel off to replace the ice chute door?
This in for a Whirlpool Model ED5JHEXTS00
Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
There should be 2 small slots in the botton for a flat blade screwdriver to fit. The trick is to not insert the screwdriver too far or it will get behind the bracket that is screwed to the door.
Just insert slightly and twist, the bottom will pop out then lift the cover up to unhook the top.
