storm2010
#1 Posted : Sunday, November 6, 2011 1:38:28 PM(UTC)
storm2010
our dishwasher seems to run for HOURS (at least 2 hours) also when complete the dishes are still soaking wet (even if left overnight) and there is a white film on most dishes. what should i do?:confused:
#2 Posted : Monday, November 7, 2011 1:40:50 AM(UTC)
A model number may help others help you.
Model Number Locator
Sounds like the heater may be blown.
Also could be a thermostat or the control board but I would check the heater first.
This will then not dry the dishes but also it will not heat the water so the unit adds delays to the cycle.
