our dishwasher seems to run for HOURS (at least 2 hours) also when complete the dishes are still soaking wet (even if left overnight) and there is a white film on most dishes. what should i do?:confused:
A model number may help others help you. Model Number LocatorSounds like the heater may be blown. Also could be a thermostat or the control board but I would check the heater first. This will then not dry the dishes but also it will not heat the water so the unit adds delays to the cycle. |
THIS FORUM IS DEAD!!!!!!! |
