beverlyjean
#1 Posted : Monday, May 18, 2009 5:38:40 AM(UTC)
beverlyjean
My Whirlpool Washer Is Leaking Water Behing The Whirlpool Pump Assemble... The Water Looks Like Its Running Down The Motor Shaft... What Do I Need To Fix This Problem....ps It Seems To Leak More When The Washer Is Filling Up....and Just Drips After This Is Completed...
#2 Posted : Monday, May 18, 2009 12:02:00 PM(UTC)
Most likely the problem is a bad pump. The correction is to replace the pump. The instructions are attached to the reply.
- The part number for the pump is AP2907492
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LSR7233DQ0 | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 17 time(s).
How to remove the pump.doc (25kb) downloaded 12 time(s).
Whirlpool washer leaking and won't fill with water (Washer Repair)
by christyhecht 6/16/2018 8:21:00 AM(UTC)
Whirlpool Washer Leaking (Washer Repair)
by DSJordan 7/17/2011 4:59:48 PM(UTC)
Whirlpool washer leaking drain pump stuck to motor shaft, how to separate to replace? (Washer Repair)
by ennemm 5/3/2009 8:06:46 AM(UTC)
whirlpool washer leaking (Washer Repair)
by rookie01 10/30/2008 5:47:51 AM(UTC)
Whirlpool Washer Leaking when filling (Washer Repair)
by mrsrdstare 9/4/2008 8:44:27 AM(UTC)
