seb123
#1 Posted : Sunday, May 17, 2009 12:42:14 PM(UTC)
seb123
My water dispenser line freezes once or twice a month. The problem corrects itself in a day or two or I have to use a hair dryer. The ice maker seems to always be full and does not seem to be effected.
Help! Just might roll the whole thing out the window!
woodchuckie
#2 Posted : Sunday, May 17, 2009 2:22:27 PM(UTC)
woodchuckie
You may have to tape some type of insulation to the inside of the freezer door in the area of the dispenser. If you can get by with a little higher temp in the freezer it might help. It needs to be around 5 or 10 degrees.
Contacting GE for warranty coverage since it may be a defective door may help.
applianceman
#3 Posted : Sunday, May 17, 2009 2:35:22 PM(UTC)
applianceman
GE makes a heater that will prevent this from happing, part number WR49X10173. GE Refrigerators Repair Guide
nvocc5
#4 Posted : Wednesday, May 20, 2009 4:59:15 AM(UTC)
nvocc5
I have a similar problem with my refrigerator. What should I do to correct this problem?
