My water dispenser line freezes once or twice a month. The problem corrects itself in a day or two or I have to use a hair dryer. The ice maker seems to always be full and does not seem to be effected.
Help! Just might roll the whole thing out the window!
You may have to tape some type of insulation to the inside of the freezer door in the area of the dispenser. If you can get by with a little higher temp in the freezer it might help. It needs to be around 5 or 10 degrees.
Contacting GE for warranty coverage since it may be a defective door may help.
I have a similar problem with my refrigerator. What should I do to correct this problem? Originally Posted by: seb123 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) My water dispenser line freezes once or twice a month. The problem corrects itself in a day or two or I have to use a hair dryer. The ice maker seems to always be full and does not seem to be effected.
