bekholt
#1 Posted : Friday, November 4, 2011 9:28:05 AM(UTC)
bekholt
As the washer is filling, some water leaks or drains back into the drain tube. How to fix?
#2 Posted : Friday, November 4, 2011 11:33:45 AM(UTC)
How and where the drain hose is connected to?
bekholt
#3 Posted : Friday, November 4, 2011 11:49:35 AM(UTC)
bekholt
The drain hose is the black sturdy ribbed plastic one that runs from the washer and empties into my drain line for the house. bae
Joe / APP Team
#4 Posted : Friday, November 4, 2011 12:03:16 PM(UTC)
Joe / APP Team
Bekolt,
Sounds like your washer is "syphoning" when it is in the fill cycle.
Make sure the top of the drain pipe is 38 inches up from the floor, and that the drain hose end is not stuck or sealed to the standpipe.
Good Luck,
bekholt
#5 Posted : Friday, November 4, 2011 12:06:55 PM(UTC)
bekholt
Hmmm. That could be the case. I'll check it out when i get home tonight and see if that works. Thank you, Gene. I greatly appreciate your help. Bruce in Tucson AZ
Joe / APP Team
#6 Posted : Friday, November 4, 2011 2:12:33 PM(UTC)
Joe / APP Team
Bruce,
Good Deal,
Let us know what you find.
