kdriscol
#1 Posted : Saturday, May 16, 2009 11:47:23 AM(UTC)
kdriscol
The spring loaded flapper door on the ice dispenser chute does not automatically close anymore and I think the spring that holds it closed needs to be replaced. But I cannot figure out how to get to the flapper door assembly. There are no visible screws on the outside (or inside) of the freezer door. Does the bezel around the ice/water dispenser in the door snap on/off? Or do I have to disassemble the whole door from the inside? The dispenser decorative bezel on the outside is plastic and I don't want to risk breaking it by trying to pry it off if there's some simple trick to getting it off. Thanks.
woodchuckie
#2 Posted : Saturday, May 16, 2009 2:10:03 PM(UTC)
woodchuckie
Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
mq43
#3 Posted : Tuesday, December 22, 2009 10:26:45 AM(UTC)
mq43
Is this the same for a Whirlpool? Using putty knife and can't seem to get it loose.
#4 Posted : Tuesday, December 22, 2009 12:15:42 PM(UTC)
Answered here: http://forum.appliancepartspros...per-door-wont-close.html
