Dryer stopped working and would just make humming sound. Assumed belt was off/stretched so I replaced it and made sure motor shaft moved freely, it did. Still did not work, so I removed drum, plugged it in and tried to start it. Same problem. I spun motor shaft with my foot and it started up... Is the motor bad or is there another component preventing the motor from spinning up on its own?
Originally Posted by: Bumpbk Dryer stopped working and would just make humming sound. Assumed belt was off/stretched so I replaced it and made sure motor shaft moved freely, it did. Still did not work, so I removed drum, plugged it in and tried to start it. Same problem. I spun motor shaft with my foot and it started up... Is the motor bad or is there another component preventing the motor from spinning up on its own? Bump, It's a bad motor, Part number: AP3094245
You're forcing the start switch circuit (in the motor) to close, when you turn the motor shaft, that's why it starts and runs, under that circumstance. :) :) :)
Thank you for your help and the fast response. New motor on the way. This site is great!
Originally Posted by: Bumpbk Thank you for your help and the fast response. New motor on the way. This site is great! Bump, Good Deal, Thanks for the compliment, we try our best. Drop us a line anytime. :) :) :)
