Robert Zivkovic
#1 Posted : Thursday, November 3, 2011 10:12:32 AM(UTC)
Robert Zivkovic
Had an electrical issue with the unit, shorted the fuse and circuit board, replaced both now will only run on extra clean and will not light up on normal cycle, does run thru the heavy cycle.
magician59
#2 Posted : Thursday, November 3, 2011 11:34:40 AM(UTC)
magician59
If this is the board you replaced, check to make sure the connections are secure; especially the ribbon connector between it and the touch pad.
Also be sure the electrical connections under the machine are secure; Make sure there is no loose ground or neutral.
Part number: AP3775964
No Water Fill…KitchenAid Dishwasher KUDS03FSSS3 (Dishwasher Repair)
by irvingtelder 11/22/2023 7:02:56 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
KUDS02FRSS2 Kitchenaid dishwasher (Dishwasher Repair)
by RepairDude61 7/2/2022 3:45:51 PM(UTC)
KitchenAid Dishwasher Not drying (Dishwasher Repair)
by louie@DFW 4/8/2022 5:15:51 PM(UTC)
Kitchenaid Dishwasher Multiple Errors (Dishwasher Repair)
by flamingvan@yahoo.com 12/6/2021 3:49:43 AM(UTC)
Kitchenaid Dishwasher F9E4 (Dishwasher Repair)
by louisd 10/17/2021 4:22:16 PM(UTC)
Kitchenaid Dishwasher diverter motor replacement (Dishwasher Repair)
by kitchdish 5/28/2021 12:32:35 PM(UTC)
KitchenAid Dishwasher Issue (Dishwasher Repair)
by facecard 3/19/2021 6:20:02 AM(UTC)
KitchenAid Dishwasher KUDS30IXBL Thermal Fuse (Dishwasher Repair)
by Ed Explains It 3/16/2021 10:34:44 AM(UTC)
KitchenAid Dishwasher will not complete cleaning Cycle (Dishwasher Repair)
by KyKatt 12/16/2020 12:23:50 PM(UTC)
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
KitchenAid dishwasher filling up when turned off (Dishwasher Repair)
by RinOakland 9/14/2020 8:50:00 AM(UTC)
KitchenAid Dishwasher pops open(latch changed) (Dishwasher Repair)
by saads 8/8/2020 9:51:27 PM(UTC)
Kitchenaid Dishwasher Not Starting (Dishwasher Repair)
by willmt10 6/28/2020 4:22:06 PM(UTC)
(Help) KitchenAid Dishwasher wont fully drain on normal cycle (Dishwasher Repair)
by ToNeG24 5/28/2020 9:16:06 PM(UTC)
