Quit working while in wash cycle, no lights on front panel, water left in dishwasher. Not circuit breaker, current to machine-yes withe voltage/ohm tester? Wondering if circuit board is shot?
Could not find this unit on this site. If this is a non US unit I will not be able to find the parts breakdown. Did get a tech sheet using the last part of the Model Number. https://www.servicematters.com/d...0Sheet%20-%208535451.pdfOdds are pretty good that the thermal fuse is blown. Remove the door's inner panel and check it. It is up by the control board. Many of the replacement fuses come in a kit which includes a harness. This lowers the odds of random blow outs. I could not confirm that this is the case with yours as I do not have the parts list/breakdown. |
THIS FORUM IS DEAD!!!!!!! |
The panel is off. Nothing looks like a thermal control fuse. Double checked the model # is 665.16039402 sound like make by Whirlpool. What wires or unit do I check?
Dishwasher bought at Sears in Fargo ND must be US unit????
