mbmdvm
#1 Posted : Friday, May 15, 2009 5:38:30 PM(UTC)
mbmdvm
Quit working while in wash cycle, no lights on front panel, water left in dishwasher. Not circuit breaker, current to machine-yes withe voltage/ohm tester? Wondering if circuit board is shot?
#2 Posted : Friday, May 15, 2009 6:40:30 PM(UTC)
Could not find this unit on this site.
If this is a non US unit I will not be able to find the parts breakdown.
Did get a tech sheet using the last part of the Model Number.
https://www.servicematters.com/d...0Sheet%20-%208535451.pdf
Odds are pretty good that the thermal fuse is blown.
Remove the door's inner panel and check it. It is up by the control board.
Many of the replacement fuses come in a kit which includes a harness. This lowers the odds of random blow outs. I could not confirm that this is the case with yours as I do not have the parts list/breakdown.
mbmdvm
#3 Posted : Friday, May 15, 2009 7:41:24 PM(UTC)
mbmdvm
The panel is off. Nothing looks like a thermal control fuse. Double checked the model # is 665.16039402 sound like make by Whirlpool. What wires or unit do I check?
mbmdvm
#4 Posted : Friday, May 15, 2009 7:43:23 PM(UTC)
mbmdvm
Dishwasher bought at Sears in Fargo ND must be US unit????
#5 Posted : Saturday, May 16, 2009 12:17:37 AM(UTC)
Could look something like this
WHIRLPOOL Dishwasher fuse kit, part number: 8193762
The above is the replacement fuse kit so it includes the harness mentioned earlier.
OR
a small disk on the board
