Cindy Catoe
#1 Posted : Friday, May 15, 2009 9:58:16 AM(UTC)
Cindy Catoe
My dryer will not start. THe light comes on but nothing happens when you push the button to start. I have checked the breaker. All is good there. What else could be the problem?
#2 Posted : Friday, May 15, 2009 5:46:03 PM(UTC)
The first thing I would do is check the thermal fuse (#6 on the diagram) for continuity.
If this fuse is open then you have to replace the high limit thermostat as well.
- The part number for the thermal fuse AP4048636
- The part number for the high limit thermostat is AP4298584
Here are the breakdown diagrams and Replacement parts for MAYTAG MDE3706AYW | AppliancePartsPros.com
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
maytag dryer will not start (Dryer Repair)
by Kevin B 10/14/2009 7:48:18 AM(UTC)
by Jay Wiggins 12/3/2008 2:54:08 PM(UTC)
