rodrbrown
#1 Posted : Saturday, December 8, 2007 11:47:32 AM(UTC)
rodrbrown
Oven temp is varying over too wide a range...
has worked fine for 8 years.
temp calibration has been done, but still not good for baking cookies.
Should I replace the oven temp probe ? element ? or ?
Whirlpool Oven Temperature Low (Oven Repair (including Ranges and Cooktops))
by topthumb 1/23/2023 11:37:05 AM(UTC)
Thermador oven temperature fluctuates (Oven Repair (including Ranges and Cooktops))
by tylert 7/4/2022 1:19:07 PM(UTC)
Oven Temperature Regulation (Oven Repair (including Ranges and Cooktops))
by Tumbleweed_2 1/27/2022 9:20:22 PM(UTC)
Jenn-Air Oven Temperature Problems (Oven Repair (including Ranges and Cooktops))
by AndyBonner 9/3/2016 8:29:21 AM(UTC)
Kenmore oven temperature issue (Oven Repair (including Ranges and Cooktops))
by Pmacd 11/12/2015 5:16:07 AM(UTC)
Oven Temperature Sensor Beyond F3 (Oven Repair (including Ranges and Cooktops))
by salquint 10/31/2015 8:36:13 AM(UTC)
Upper oven temperature lower than displayed by 75degrees (Oven Repair (including Ranges and Cooktops))
by BillIan 10/22/2014 12:41:56 PM(UTC)
Oven temperature low (Oven Repair (including Ranges and Cooktops))
by Yuan 5/20/2014 4:27:30 PM(UTC)
Won't maintain oven temperature (Oven Repair (including Ranges and Cooktops))
by Ingridmoore66 4/19/2014 5:50:15 AM(UTC)
older model GE Profile oven temperature won't stay on (Oven Repair (including Ranges and Cooktops))
by kysowns 1/8/2014 8:45:42 PM(UTC)
Kenmore oven temperature problem (Oven Repair (including Ranges and Cooktops))
by dro53 9/11/2013 8:17:13 PM(UTC)
by spatman 6/21/2013 8:12:54 AM(UTC)
Oven temperature Control on GE XL44 B (Oven Repair (including Ranges and Cooktops))
by Kpaul 1/14/2013 1:28:20 PM(UTC)
Oven Temperature 25 degrees lower than display (Oven Repair (including Ranges and Cooktops))
by geebekazoo 12/12/2012 10:27:31 AM(UTC)
Oven Temperature decreases while baking (Oven Repair (including Ranges and Cooktops))
by gturzo 11/6/2012 3:33:40 PM(UTC)
