jonandjanc
#1 Posted : Monday, May 11, 2009 3:14:46 PM(UTC)
jonandjanc
My washer spins slowly with little torque,the motor and gearbox are rotating o.k. but I notice that the clutch pads are not making contact with the drum,can these be adjusted and how difficult is it to do so?
sidfink43
#2 Posted : Tuesday, May 12, 2009 5:23:23 PM(UTC)
sidfink43
I would recommend you replace the clutch. Be sure you also check the drain system, including the pump and hoses.
Here is a good site that will explain how.
Clutch Replacement on Whirlpool and Kenmore Washers
Good luck and let us know how it turns out.
jonandjanc
#3 Posted : Friday, May 15, 2009 1:34:51 PM(UTC)
jonandjanc
The parts are on order I'll let you know,Thanks....
