merlin6543
#1 Posted : Thursday, October 27, 2011 7:41:08 PM(UTC)
merlin6543
The machine will not pump the water out of the bottom.
I have cleaned it out and tried it twice with no luck.
Is there a way to clean it out further? Or what is the next step?
merlin6543
#2 Posted : Friday, October 28, 2011 7:28:40 AM(UTC)
merlin6543
I have removed debris from pump impeller. Water can be removed from hose drain and flows freely.
However the pump will not evacuated the water in bottom of machine, but appears to be agitated by pump impellor.
Guest (4)
maytag washer will not drain water (Washer Repair)
by mathy10544 12/13/2015 8:54:09 PM(UTC)
GE washer will not drain water in Spin Cycle (Washer Repair)
by a1handy 3/21/2012 2:11:55 PM(UTC)
maytag sometimes will not drain water (Washer Repair)
by takloss@msn.com 12/30/2011 6:49:56 PM(UTC)
Will not drain water (Dishwasher Repair)
by hagop 2/4/2008 4:11:02 PM(UTC)
