a1handy
#1 Posted : Wednesday, March 21, 2012 2:11:55 PM(UTC)
a1handy
This is a washer I purchased as a new return from Lowes. It has never been used and was returned because the water will not pump out after the spin cycle. I feel the problem must be with the electronics. Please advise.
#2 Posted : Wednesday, March 21, 2012 3:51:28 PM(UTC)
Remove the front panel and check for 120 VAC to the drain pump while the control calls for drain.
Post the results.
Here are the breakdown diagrams and Replacement parts for General Electric WHSE5240D1WW Washer | AppliancePartsPros.com
