The dishwwasher sticks in the wash cycle. I replaced the hi-temp thermostat but made no difference. I ohmed out the heating element, seems to be ok. The heating element does not get hot.
If there is nothing wrong with the thermostat and the wires then check the push button switch according to the wiring diagram. If the switch is good then the problem is a bad timer. - The part number for the push button switch is AP2109515 - The part number for the timer is AP3214744Gene.
