Dennismull
#1 Posted : Monday, May 11, 2009 7:48:01 AM(UTC)
Dennismull
The dishwwasher sticks in the wash cycle. I replaced the hi-temp thermostat but made no difference. I ohmed out the heating element, seems to be ok. The heating element does not get hot.
#2 Posted : Monday, May 11, 2009 4:41:51 PM(UTC)
If there is nothing wrong with the thermostat and the wires then check the push button switch according to the wiring diagram.
If the switch is good then the problem is a bad timer.
- The part number for the push button switch is AP2109515
- The part number for the timer is AP3214744
