This is the Elite Heat 3 to the 3rd? 110.82836100 model. I'm receiving and error code E1 and unit shuts down. I suspect its the thermostat. Manual just says call for service. I am an electrical repair technician for a major newspaper chain and if told what the problem is, most likely could replace bad part. Any help would be appreciated.
Thank you.
Well, the manual would say that wouldn't it. Welcome to the wonderful world of appliance electronics. I think your problem is in the thermistor, which monitors heat in the venting system. You can test it with a meter, and if itis open, just replace it and see if that does not fix your problem. The repair is both cheap and easy. Here is a manual which I think is either for your machine or close enough to be of use. https://secured.whirlpoo...6be0c0/$FILE/8178601.pdfGood luck and let us know how it turns out.
Originally Posted by: sidfink43 Well, the manual would say that wouldn't it. Welcome to the wonderful world of appliance electronics. I think your problem is in the thermistor, which monitors heat in the venting system. You can test it with a meter, and if itis open, just replace it and see if that does not fix your problem. The repair is both cheap and easy. Here is a manual which I think is either for your machine or close enough to be of use. https://secured.whirlpoo...6be0c0/$FILE/8178601.pdfGood luck and let us know how it turns out. Thank You for your suggestion and the manual. I will try this and report back. Thank You so much. Mr Matt Robinson
