mdrobinson
#1 Posted : Sunday, May 10, 2009 7:52:57 AM(UTC)
mdrobinson
This is the Elite Heat 3 to the 3rd? 110.82836100 model. I'm receiving and error code E1 and unit shuts down. I suspect its the thermostat. Manual just says call for service. I am an electrical repair technician for a major newspaper chain and if told what the problem is, most likely could replace bad part. Any help would be appreciated.
Thank you.
sidfink43
#2 Posted : Sunday, May 10, 2009 10:24:49 AM(UTC)
sidfink43
Well, the manual would say that wouldn't it. Welcome to the wonderful world of appliance electronics.
I think your problem is in the thermistor, which monitors heat in the venting system. You can test it with a meter, and if itis open, just replace it and see if that does not fix your problem. The repair is both cheap and easy.
Here is a manual which I think is either for your machine or close enough to be of use.
https://secured.whirlpoo...6be0c0/$FILE/8178601.pdf
Good luck and let us know how it turns out.
mdrobinson
#3 Posted : Monday, May 11, 2009 12:10:54 PM(UTC)
mdrobinson
Thank You for your suggestion and the manual. I will try this and report back. Thank You so much.
Mr Matt Robinson
