LARRY JUSTICE
#1 Posted : Monday, July 30, 2007 6:41:02 AM(UTC)
LARRY JUSTICE
Soap Drawer Will No Open ,this Is The Second Time It's Failed
Repaired On Feb 2007,by Replacing Board And Drawer Assy
Any One Know The Key Seq To Test This Dishwasher !
#2 Posted : Monday, July 30, 2007 10:50:52 PM(UTC)
LARRY JUSTICE
The technical data suppose to be in a pouch behind the bottom panel. You have to remove the panel and it should be on the other side. If it's not there then you can find it here: Service Matters - Tech Sheets / Wiring Diagrams
The model number you provided is not complete, so I picked up the closest one which is KUDI02FRBL0.
Good luck.
LARRY JUSTICE
#3 Posted : Tuesday, July 31, 2007 8:15:05 AM(UTC)
LARRY JUSTICE
thanks gene
for the online resource !!
larry justice
Kitchen aid dishwasher bottom leaking (Dishwasher Repair)
by Guest 4/21/2024 10:31:25 AM(UTC)
Kitchen Aid Dishwasher - KUDS25SHBT1 (Dishwasher Repair)
by Karen M 10/19/2022 10:03:13 AM(UTC)
Kitchen Aid Dishwasher Upper Spray Arm (Dishwasher Repair)
by Guest 1/13/2022 12:58:02 PM(UTC)
Kitchen Aid Dishwasher KUPC10FxSS5 Di (Dishwasher Repair)
by Andrew Glass 9/27/2021 11:37:55 AM(UTC)
Kitchen aid dishwasher KUDS01FLSS5 - top rack doesn't get wet and soap residue (Dishwasher Repair)
by Joe D Raleigh 10/13/2019 3:25:49 PM(UTC)
Kitchen Aid Dishwasher Screech (Dishwasher Repair)
by mark.stacy@emc.com 11/5/2018 6:45:56 PM(UTC)
Kitchen Aid Dishwasher Blinking Lights (Dishwasher Repair)
by T/Y4HELP 8/7/2016 5:20:39 AM(UTC)
No lights on Kitchen aid dishwasher (Dishwasher Repair)
by Gschimma 12/22/2015 7:02:06 PM(UTC)
Kitchen Aid Dishwasher Not Draining (Dishwasher Repair)
by jrdardano 7/18/2015 1:23:21 PM(UTC)
kitchen aid dishwasher drain motor will not run (Dishwasher Repair)
by phantomjet 4/22/2015 8:17:13 PM(UTC)
kitchen aid dishwasher (Dishwasher Repair)
by jacquesaccount 8/21/2014 8:15:31 AM(UTC)
Kitchen Aid dishwasher stopped working (Dishwasher Repair)
by acillatem 6/15/2014 6:12:42 PM(UTC)
Kitchen Aid dishwasher doesn't drain completely (Dishwasher Repair)
by rgjhnsn 5/31/2014 5:57:43 PM(UTC)
Kitchen Aid Dishwasher won't start (Dishwasher Repair)
by waveraider 1/30/2014 9:00:51 PM(UTC)
Kitchen Aid Dishwasher: Blinking Lights, Unfinished Cycle General Malaise (Dishwasher Repair)
by 3Zero 10/24/2013 4:57:00 PM(UTC)
