ARS2664AC
#1 Posted : Friday, May 8, 2009 3:29:39 PM(UTC)
ARS2664AC
The white tube inside the freezer that fills the icemaker froze up. I was able to thaw it out with a hair dryer and remove the ice inside the tube. What happens now is that when I fill a glass with water from the freezer door, water trickles out of the tube, overflows the ice maker and dumps into the ice bucket, freezing everything up. From what I read, the problem seems to point to the valve with the blue cap on it that is located on the back of the frige, on the bottom right, and has the plastic hose to the ice maker coming out of it. I just want to verify that I am on the right track, instead of just throwing parts into the thing. Thanks in advance.
Paul
Drags1998
#2 Posted : Friday, May 8, 2009 4:29:41 PM(UTC)
Drags1998
You are correct, Replace the water valve!!!!:)
ARS2664AC
#3 Posted : Friday, May 8, 2009 10:47:49 PM(UTC)
ARS2664AC
Thanks for the quick response! Much appreciated!
ARS2664AC
#4 Posted : Saturday, May 16, 2009 11:38:41 PM(UTC)
ARS2664AC
It turns out that I had to replace both the primary and secondary water valves. Once done, all is now well in the world of my Amana Refrigerator.
avpatjac
#5 Posted : Saturday, October 24, 2009 9:31:10 AM(UTC)
avpatjac
I saw your post. In my case the water line connection to the Ice Maker Fill Tube on the back of the refrigerator has broken. I need to replace the entire fill tube. How does the fill tube come out? Do I simply pop it out somehow?
Ice Maker tube frozen (Refrigerator & Freezer Repair)
by gfrench12001 10/5/2013 2:37:09 PM(UTC)
