The right drum roller (facing the dryer) on my Maytag electric dryer LDE7334ACM squeals after the dryer runs for a few minutes. A shot of WD40 removes the squeal for a few weeks, but it returns after that. Sounds like I need to replace the rollers? I need parts and instructions to replace.
Here are your parts Replacement parts for MAYTAG LDE7334ACM | AppliancePartsPros.comSee item 21 in the "Tumbler" section You will need a pair of cir (sir) clip pliers to get them off. You may also want to check the shafts for wear. Just a note WD40 is not a very good oil. You would be better off with sewing machine oil or 3in1 or something like Jig.A.Loo |
THIS FORUM IS DEAD!!!!!!! |
