teerlirs
#1 Posted : Friday, May 8, 2009 11:20:06 AM(UTC)
teerlirs
The right drum roller (facing the dryer) on my Maytag electric dryer LDE7334ACM squeals after the dryer runs for a few minutes. A shot of WD40 removes the squeal for a few weeks, but it returns after that. Sounds like I need to replace the rollers? I need parts and instructions to replace.
#2 Posted : Friday, May 8, 2009 1:13:11 PM(UTC)
Replacement parts for MAYTAG LDE7334ACM | AppliancePartsPros.com
See item 21 in the "Tumbler" section
You will need a pair of cir (sir) clip pliers to get them off.
You may also want to check the shafts for wear.
Just a note WD40 is not a very good oil.
You would be better off with sewing machine oil or 3in1 or something like Jig.A.Loo
