I just replaced the ice maker and it is harvesting ice but the ice cubes are coming out not frozen enough and they stick together. Is there a thermostat that controls the temp of the ice maker or a timer to adjust to let the ice sit a little longer before ejecting?
One thing that can cause this is that it’s not getting enough water. This will cause the thermostat to cycle to quickly. Refrigerator repair guide
[FONT='Times New Roman']If not check the temperature inside the freezer and see if it seems to be ok. Finally yes, there is a thermostat that can cause this located inside the icemaker. [/FONT]
