My direct drive washer will not agitate or spin. I have done the motor reset, removed the front panel and verified the belt is OK. By observation I can see nothing running or trying to run at the motor assembly. Can you give me a heads up on how to proceed in troubleshooting? Thanks in advance.
This site here will take you through some troubleshooting HydroWave GE Washer Repair GuideIt may be as easy as a fuse, or resetting it using the instruction on that site.
