wfree12
#1 Posted : Sunday, October 23, 2011 4:50:58 PM(UTC)
wfree12
My direct drive washer will not agitate or spin. I have done the motor reset, removed the front panel and verified the belt is OK. By observation I can see nothing running or trying to run at the motor assembly. Can you give me a heads up on how to proceed in troubleshooting? Thanks in advance.
sidfink43
#2 Posted : Tuesday, October 25, 2011 6:02:42 PM(UTC)
sidfink43
This site here will take you through some troubleshooting
HydroWave GE Washer Repair Guide
It may be as easy as a fuse, or resetting it using the instruction on that site.
GE washer Problems w/ Agitation GCWN3000M1WS (Washer Repair)
by ps33 12/19/2020 4:19:13 PM(UTC)
GE Washer Problem (Washer Repair)
by erat76 11/19/2012 7:52:12 AM(UTC)
GE washer problem (Washer Repair)
by tampaguy 2/9/2012 11:36:19 AM(UTC)
GE washer problems (Washer Repair)
by kosmo_7@comcast.net 5/18/2011 1:28:31 PM(UTC)
GE Washer problems with cycles (Washer Repair)
by jbhew 4/6/2011 9:27:21 AM(UTC)
by gpetty3 10/26/2009 3:50:10 PM(UTC)
ge washer problem (Washer Repair)
by dg775577 7/19/2008 6:26:05 PM(UTC)
