when I start the washer it automaticaly start to agitate and no water comes in. The inlet valve has been checked and is good. How would I check the continuallity of current flowing from switch to switch?
The problem IS the water level switch!!!! TRY rotating it back and forth QUICKLY a few times.(Its stuck inside). If this dosent help, Replace the WATER LEVEL SWITCH!!!:)
I have very similar problem on GE wdsr2080d8ww
when I start the washer it automaticaly start to agitate and no water comes in... As per your post above... How do I check it is a water level switch? And how do I replace the water level switch?
