James Hamilton
#1 Posted : Wednesday, May 6, 2009 1:05:45 PM(UTC)
James Hamilton
when I start the washer it automaticaly start to agitate and no water comes in. The inlet valve has been checked and is good. How would I check the continuallity of current flowing from switch to switch?
Drags1998
#2 Posted : Wednesday, May 6, 2009 1:14:11 PM(UTC)
Drags1998
The problem IS the water level switch!!!! TRY rotating it back and forth QUICKLY a few times.(Its stuck inside). If this dosent help, Replace the WATER LEVEL SWITCH!!!:)
jonlim1208
#3 Posted : Wednesday, June 24, 2009 7:22:03 PM(UTC)
jonlim1208
I have very similar problem on GE wdsr2080d8ww
when I start the washer it automaticaly start to agitate and no water comes in...
As per your post above... How do I check it is a water level switch? And how do I replace the water level switch?
