whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... does this have a defrost timer (cant find) or some kind of frost controls??? looking for a solution to fix...fans work fine... How do I test without a timer???? any help would be great.
Here are your parts Replacement parts for WHIRLPOOL GB2SHTXTS00 | AppliancePartsPros.comHere is the tech sheet note it is for a S11 could not find one for a S00, but should be very close to yours. https://www.servicematters.com/d...Sheet%20-%2012827961.pdf It shows how to force a defrost. does this have a defrost timer (cant find) or some kind of frost controls??? Defrost is run by the control board How do I test without a timer???? See the tech sheet. Here are a couple good links on fridge repair: Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com http://www.applianceaid.com/refrigerator.htmlIf you do not own a meter, I would suggest you purchase a one. You can get a decent digital multimeter for under $20.00. You do not need fancy though it is nice if the leads are a couple feet long. If it saves ordering one unnecessary part it has paid for itself and you end up owning a useful tool. Most places will not let you return electrical parts so if you order it, you own it. A couple things to watch when measuring ohms and continuity 1. Always remove power from the machine otherwise you could blow your meter. 2. Always disconnect at least one side of any device you are checking. This eliminates the possibility of measuring an alternate/parallel circuit path. 3. When checking for closed contacts and continuity use the lowest scale (Usually 200 ohms). Then try higher scales. This scale is 0 to 200 ohms so if the device you are measuring is 300 ohms this scale would show an open circuit which it is not, you are just measuring outside the scale's dynamic range. There is a good STICKY at the start of this forum about it's use. |
THIS FORUM IS DEAD!!!!!!! |
thanks , is the computer by the compressor... yes I have fluke meter
Yes it looks like that is where it is.
Remove the covers from the evaporator coils Try forcing a defrost If the heater heats then your problem is probably the defrost control. Be careful that you do not burn your fingers. Note the defrost thermostat must be frozen for the heater to run, it disconnects power to the heater just above freezing. If the heater does not heat up during a forced defrost. Unplug the unit Check the heater (30 ohms approx.) Check the defrost thermostat (0 ohms) |
i ran the service test everything appeared good.. that really helped out.....thermostat was closed... heater heated up in forced deforst.. check the heater 30 ohms checked the stat 0.5 ohms.....the coils were slightly frosted over.. I thawed it several days back...wondering if it is gonna freeze up again??? and stop cooling the refrigerator.. could it be possible the computer is bad or low on refrigerant????? causing the refr. not to cool when it frost up
I thawed it several days back...wondering if it is gonna freeze up again??? and stop cooling the refrigerator.. For it to be a defrost problem the coils have to be heavily iced/frosted up. So much so that the fan cannot pull air through the fins.
could it be possible the computer is bad Since the defrost is OK when forced, the heater and thermostat are OK so all that is left is the control board not going into a defrost mode when it should or low on refrigerant????? causing the refr. not to cool when it frost up Depends on how frosted up it was. Usually if you have low freon you will see it will only frost up on part of the evaporator coils. Let it run for a few hours and take a look. The coils should have a light and fairly even coating of frost.
You may also want to check the defrost thermostat sometimes they also use it's value as part of a defrost. If you ran the diags you have probably already done this. |
Again not cooling, I checked the heater I checked the stat...seemed fine.now I guess it is the computer board?????? Is this difficult to change? I suppose it is in the compressor compartment??? on the GB2STXTS00 bottom freezer Originally Posted by: denman ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I thawed it several days back...wondering if it is gonna freeze up again??? and stop cooling the refrigerator.. For it to be a defrost problem the coils have to be heavily iced/frosted up. So much so that the fan cannot pull air through the fins.
