bobacus
#1 Posted : Wednesday, May 6, 2009 4:59:46 AM(UTC)
bobacus
whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up...
does this have a defrost timer (cant find) or some kind of frost controls???
looking for a solution to fix...fans work fine... How do I test without a timer???? any help would be great.
#2 Posted : Wednesday, May 6, 2009 6:40:26 AM(UTC)
Replacement parts for WHIRLPOOL GB2SHTXTS00 | AppliancePartsPros.com
Here is the tech sheet note it is for a S11 could not find one for a S00, but should be very close to yours.
https://www.servicematters.com/d...Sheet%20-%2012827961.pdf
It shows how to force a defrost.
Defrost is run by the control board
See the tech sheet.
Here are a couple good links on fridge repair:
Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
http://www.applianceaid.com/refrigerator.html
bobacus
#3 Posted : Wednesday, May 6, 2009 7:11:32 AM(UTC)
bobacus
thanks , is the computer by the compressor... yes I have fluke meter
#4 Posted : Wednesday, May 6, 2009 8:36:40 AM(UTC)
Yes it looks like that is where it is.
Remove the covers from the evaporator coils
Try forcing a defrost
If the heater heats then your problem is probably the defrost control.
Be careful that you do not burn your fingers.
Note the defrost thermostat must be frozen for the heater to run, it disconnects power to the heater just above freezing.
If the heater does not heat up during a forced defrost.
Unplug the unit
Check the heater (30 ohms approx.)
Check the defrost thermostat (0 ohms)
bobacus
#5 Posted : Friday, May 8, 2009 4:03:08 AM(UTC)
bobacus
i ran the service test everything appeared good.. that really helped out.....thermostat was closed... heater heated up in forced deforst.. check the heater 30 ohms checked the stat 0.5 ohms.....the coils were slightly frosted over.. I thawed it several days back...wondering if it is gonna freeze up again??? and stop cooling the refrigerator.. could it be possible the computer is bad or low on refrigerant????? causing the refr. not to cool when it frost up
#6 Posted : Friday, May 8, 2009 5:58:48 AM(UTC)
For it to be a defrost problem the coils have to be heavily iced/frosted up.
So much so that the fan cannot pull air through the fins.
Since the defrost is OK when forced, the heater and thermostat are OK so all that is left is the control board not going into a defrost mode when it should
Depends on how frosted up it was. Usually if you have low freon you will see it will only frost up on part of the evaporator coils. Let it run for a few hours and take a look. The coils should have a light and fairly even coating of frost.
You may also want to check the defrost thermostat sometimes they also use it's value as part of a defrost. If you ran the diags you have probably already done this.
bobacus
#7 Posted : Thursday, May 21, 2009 3:02:02 AM(UTC)
bobacus
Again not cooling, I checked the heater I checked the stat...seemed fine.now I guess it is the computer board?????? Is this difficult to change? I suppose it is in the compressor compartment??? on the GB2STXTS00 bottom freezer
