mags10
#1 Posted : Tuesday, May 5, 2009 10:20:11 AM(UTC)
mags10
We Have a Kenmore/Frigidaire Stack W/D. EVERYTHING works EXCEPT water won't shut off when it reaches the selected level, nor will it agitate...It WILL spin and exit the standing water when U turn the 'selector' to that point...
#2 Posted : Tuesday, May 5, 2009 1:39:58 PM(UTC)
Check the pressure hose connection to the pressure switch (#5 on the diagram)
If there is nothing wrong then the pressure switch has to be replaced.
- The part number for the pressure switch is AP3867022
