We Have a Kenmore/Frigidaire Stack W/D. EVERYTHING works EXCEPT water won't shut off when it reaches the selected level, nor will it agitate...It WILL spin and exit the standing water when U turn the 'selector' to that point...
Check the pressure hose connection to the pressure switch (#5 on the diagram) If there is nothing wrong then the pressure switch has to be replaced. - The part number for the pressure switch is AP3867022Gene.
