Tom F
#1 Posted : Tuesday, May 5, 2009 7:09:35 AM(UTC)
Tom F
Our Speed Queen washer makes too much noise during the spin cycle that it's obvious that the bearings are going. What bearings need to be replaced and is this something worth doing on a machine this old?
#2 Posted : Tuesday, May 5, 2009 2:22:16 PM(UTC)
Hi Tom,
This is about 3-4 hours job and you probably have to buy some special tool. I do not think this washer is worth it.
Here are the breakdown diagrams and Replacement parts for AMANA HA5001 | AppliancePartsPros.com
Cabrio bearing replacement (Washer Repair)
by Guest 2/26/2024 4:58:10 AM(UTC)
LG front-load washer, bearing replacement (Washer Repair)
by nolanday 7/9/2022 1:40:59 PM(UTC)
Lessons learned Whirlpool Cabrio Platinum bearing replacement (Washer Repair)
by appliancemonkey 6/30/2020 9:32:58 PM(UTC)
Tight drive pulley after bearing replacement (Washer Repair)
by maverick 5/24/2017 9:48:04 AM(UTC)
W10435302 Bearing replacement Kit - Tips and Advice (second try) (Washer Repair)
by Madd0c 3/11/2017 12:12:56 PM(UTC)
Bearing replacement still not fixed (Washer Repair)
by jfixer 1/28/2017 11:46:16 AM(UTC)
Bearing replacement on Neptune? (Washer Repair)
by Sailandfly 8/15/2014 6:26:36 AM(UTC)
tub bearing replacement (Washer Repair)
by tybotee 12/13/2013 9:26:40 AM(UTC)
Amana Bearing Replacement (Washer Repair)
by Gearfish 10/22/2013 8:18:53 PM(UTC)
LG WM2487HwM - separating inner tub from outer for bearing replacement (Washer Repair)
by TravisR 7/26/2013 9:51:34 PM(UTC)
Help with Kenmore dryer bearing replacement (Dryer Repair)
by frank5 3/9/2013 5:59:21 AM(UTC)
Maytag Washer Tub still loose after bearing replacement (Washer Repair)
by lgmccoy1 12/14/2011 9:28:25 AM(UTC)
Spin Cycle Bearing Replacement (Washer Repair)
by Clinton Bele 9/19/2011 3:18:32 PM(UTC)
Maytag Neptune - Bearing Replacement (Washer Repair)
by buller 7/6/2011 9:48:11 AM(UTC)
Maytag bearing replacement? (Washer Repair)
by TimL 5/11/2011 8:46:58 AM(UTC)
