SteveM
#1 Posted : Wednesday, December 5, 2007 3:08:23 PM(UTC)
SteveM
Rank:: Member
The microwave has no power to the control panel. Checked breaker box, it's ok. The interior light DOES work. The work light, fan and control panel are dead. I found the parts lists and simple diagrams but my problem is that I don't know how to get to the FUSE inside the unit. The diagram looks like the FUSE is behind the control panel on the right side of the unit. I need help removing the panels to access the FUSE. Thanks.
#2 Posted : Wednesday, December 5, 2007 4:44:04 PM(UTC)
If the interior light does work then there is nothing wrong with the fuse.
Most likely the problem is a bad control board.
In order to get access to the parts behind the control panel you have to remove two screws holding the top panel (aka vent grill) first and pull the top panel toward yourself.
Remove the screw on top of the control panel, slide it up to release from the tabs and pull it out.
- The part number for the control board AP3119663
- Here are the break down diagrams for the Whirlpool microwave Model MH6110XEB0
Frigidaire FFHB2740PS2 No Power (Refrigerator & Freezer Repair)
by mnjeepmale 6/3/2024 5:19:45 AM(UTC)
Samsung Gas Dryer no power (Dryer Repair)
by glenn55 5/19/2024 3:33:32 PM(UTC)
kenmore elite smartheat quietpak 9 control has no power (Dryer Repair)
by Guest 2/18/2024 10:39:22 PM(UTC)
Gdf520pgj2ww dishwasher no power (Dishwasher Repair)
by pbajr 8/18/2023 1:00:22 PM(UTC)
GDF610PMJ5ES (GE Dishwasher) - No Power to LED Display (Dishwasher Repair)
by txwildcard 6/7/2023 2:40:51 PM(UTC)
GE JVM1540DM5WW suddenly no power a few seconds into starting it. (Microwave Repair)
by Guest 4/16/2023 11:55:25 AM(UTC)
Fridge - No power (Refrigerator & Freezer Repair)
by Guest 1/19/2023 7:36:28 PM(UTC)
Thermador t18id900lp no power (Refrigerator & Freezer Repair)
by whosurpopi 11/15/2022 9:25:21 AM(UTC)
No power to ice and water in Frigidaire FFHS2311PFEA (Refrigerator & Freezer Repair)
by Slbno1 10/12/2022 11:12:10 AM(UTC)
lg tromm dryer no power (Dryer Repair)
by Guest 8/25/2022 8:16:12 AM(UTC)
Frigidaire FGHS2631PF4A No Power (Refrigerator & Freezer Repair)
by hpreston35 8/24/2022 2:40:22 PM(UTC)
GE Dishwasher - No Power - Replaced Control Board, Wiring Harnes, and UI Board (Dishwasher Repair)
by aervin 4/19/2022 7:32:28 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No power to control panel Kenmore Elite dishwasher model 665.12793k311 (Garbage Disposer Repair)
by John Boof 2/2/2022 6:56:51 PM(UTC)
Maytag washer no power (Washer Repair)
by Guest 10/28/2021 12:07:08 PM(UTC)
