Having problem with freezer coils freezing. It is as if I'm not getting any power to the defrost coil. In sevice mode 1 it shows that the defrost thermostat in the shorted position.To me that shows that power should be going through the defost coil and it 's not. Does this mean I need a new control panel?
Originally Posted by: Gene ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) Gene I put the refrigerator in forced defrost and it did defrost the coil. Then the thermostat did show open in the service mode 1. So then it would be the control panel correct? I don't quite understand pin 3 function on terminal board j1. It says d-sense does that mean defrost sensor and how does it work?
