gwood
#1 Posted : Monday, May 4, 2009 9:28:00 AM(UTC)
gwood
I have the replacement part 'Water-Actuator'. But I don’t have the specs to perform the installation. This is the pedal that is pushed to distribute water into a drinking glass. I'm not sure if the frame that surrounds the water and ice pedals just pops off to access were it needs to be installed?
woodchuckie
#2 Posted : Monday, May 4, 2009 11:40:14 AM(UTC)
woodchuckie
Remove the dispenser cover by gently prying going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
